Author Topic: Get the index of the item (package, element . . .)  (Read 7482 times)
ALL_IN_ONE
« on: June 04, 2010, 01:11:08 pm »
Hello all,
I would like to delete the modal projekt items. For example I have the id of method and to delete that method I need the index of the method. thus what I do : I iterate like shown below
int methodIDTobedel = 5468;
for(short index = 0, index < elemObjeckt.Methods.count;index++)
      EA.Method methodObj = elemObjeckt.Methods.GetAt(i) as EA.Method;
      if(methodObj.MethoID == methodIDTobedel )
         elemObjeckt.Methods.DeleteAt(index ,FALSE);
         break;
From the above code I have to iterate through all the methods and only one of them will be true.
Thus my question is if I have the ID of the method to be deleted can I also get the index of the method with the help of id. This will reduce unnecesary time of iteration.
*** I also tried  elemObjeckt.Methods.GetByName(string name) . .. but we have methods with the same name tooooo .. i think its not reliable . .
ALL_IN_ONE
Re: Get the index of the item (package, element .
« Reply #1 on: June 04, 2010, 03:42:08 pm »
All_In_One
I think that is indeed the only way to delete an item. (unfortunately).
If there is a better way I'd love to know (since my code looks exactly the same as yours)
ALL_IN_ONE
« Reply #2 on: June 04, 2010, 04:32:18 pm »
Hello Geert,
Thanx for your reply.
Hmmm . . . .may be I will requst sparx to look for an optimize way to delete an item rather than using the index . . . .
Or may be there should be an additional method like
int GetMethodIndex(int MethodID)
But I also believe the index of the operation will not remain the same once they are deleted and refreshed. Thus after the refresh the remaining methods will have a new index.
ALL_N_ONE
mrf
« Reply #3 on: June 04, 2010, 04:42:06 pm »
This is completely untested (its getting towards the end of the day, so I'll try and test it tommorow), BUT:
You could possibly use Repository.GetElementSet() to get a collection that contains only the elements that you want to delete, and then delete them.
Disclaimer: May or may not work  8-)
Best Regards,
Michael
mrf
« Reply #4 on: June 04, 2010, 04:45:02 pm »
Actually it won't work because you're after methods not elements :(
Best Regards,
Michael
ALL_IN_ONE
« Reply #5 on: June 04, 2010, 04:57:21 pm »
Hello MRF,
It would be great if we have for all the below ones . . .
The future method  :)     ::)
GetObjectSet(ObjectType,string IDList,long Options)
it should cover any type of object covered in EA otProject
otElement, otClient, otPAckage, otDatatype, otConnector . . . . . and so on
@Geert : What do you think about  it
ALl_IN_ONE
« Reply #6 on: June 04, 2010, 05:08:24 pm »
If you are sending a request, then I would rather ask for a Delete() method on all classes that have an Update() method.
Wouldn't that be a lot easier?
« Reply #7 on: June 04, 2010, 05:09:35 pm »
And this is also a very good idea (but a different request)
ALL_IN_ONE
« Reply #8 on: June 04, 2010, 05:30:59 pm »
Hello
yes having an upadate option within the Delete() is good . . .
but I am not sure how that will reduce the time in processing . . . .
Newaz in the meant time I will send them the request for
1) int GetObjectIndex(EA.ObjectType ObjectType, int objectID);
2) GetObjectSet( EA.ObjectType ObjectType,string IDList,long Options);
3) bool DeleteFor(int[] index, bool Refresh);
hope te above ones help others toooo . . . ::)
ALL_IN_ONE
« Reply #9 on: June 04, 2010, 05:35:55 pm »
It will reduce time in processing because then you can do:
EA.Method methodObj = GetMethodByID(methodIDTobedel);
methodObj.Delete();
So no more need to iterate anything, and you don't even have to get the containing Element.
ALL_IN_ONE
« Reply #10 on: June 04, 2010, 05:45:09 pm »
Hello
oh ok . . now in got your point . .
I think this is really good, short and simple  . . .
All_IN_ONE
