Author Topic: Counting packages and elements  (Read 5607 times)
radio99
« on: March 04, 2016, 01:39:53 pm »
I have a very large model (root node and hundreds of sub-packages) all under version control.  I have been asked to provide a count on the number of sub-packages and also the total elements in the model.   Is there a way to retrieve this via a built-in function or using the sql engine within EA?
Re: Counting packages and elements
« Reply #1 on: March 04, 2016, 02:52:46 pm »
From the main menu go Project > Status and then look at the Project Statistics tab.
Helmut Ortmann
« Reply #2 on: March 04, 2016, 04:54:03 pm »
another possibility is SQL. With SQL you get almost everything from the repository.
An example relating your case:
select count(*), Object_Type from t_object group by Object_type
Helmut
