Author Topic: Diagram "key"  (Read 6651 times)
Whil
Diagram "key"
« on: March 09, 2016, 08:30:03 pm »
Hi Forum and members,
Is there a way in Enterprise Architect to include a "key" in a diagram? By "key" I mean a sort of legend, but used to explain the type of object or relation.
As an example, let's say I want to draw a simple UML class diagram with two classes and a "generalize" arrow connecting them. In the diagram I want to include a "key" showing (1) the visual of the arrow with an explanation saying "Generalization" and (2) the visual of a class-box with the explanation saying "class".
Is that doable?
Best regards
Gustav
Re: Diagram "key"
« Reply #1 on: March 09, 2016, 08:42:57 pm »
Yes, using custom images.
But really you shouldn't. Generalizations and classes are part of the UML standard and they should be known by your audience.
Whil
Re: Diagram "key"
« Reply #2 on: March 10, 2016, 07:43:44 am »
Ok, thanks Geert.
I'd argue the value of the key anyways though. Maybe not as much for UML-diagrams since each specific visual has a certain pre-defined meaning. But one shouldn't assume to much from the audience. Giving a key will only make it clearer - even though some might think it superfluous.
A key would simplify the creation of informal models and diagrams using EA too, imo.
BR
Gustav
Glassboy
Re: Diagram "key"
« Reply #3 on: March 10, 2016, 08:30:10 am »
Well, you could always create a diagram called "key" or "legend", and include it on your diagram as a diagram frame.
Uffe
Re: Diagram "key"
« Reply #4 on: March 11, 2016, 01:26:42 am »
Here's an idea:
  • Open a diagram of whatever type you're interested in and undock the diagram toolbox. Switch on all labels.
  • Take a dump of the toolbox window using your favourite screen dump tool (Greenshot, Snagit, etc).
  • Import the image into the EA project's image library.
  • Paste the image into those diagrams you want non-modellers to be able to read.
Of course, the toolbox doesn't cover all possible element and connector types you might show in a diagram, but if you're dealing with people who can't read diagrams in the first place you should keep the number of element / connector types down anyway. The less you can expect from the audience, the more careful you have to be as an author.
/Uffe
Re: Diagram "key"
« Reply #5 on: March 11, 2016, 01:58:11 am »
Here's another idea: get a training for the people that are going to read the diagrams. Without knowing what a connector/element means, a legend is of not much help.
Whil
Re: Diagram "key"
« Reply #6 on: March 11, 2016, 08:39:38 am »
Thanks for the creativity guys.
Making a key using an imported image seems like the current way to go. "Hack it" that is.
Regards
