Author Topic: Default data type in a new Code Eng. Language?  (Read 5353 times)
Guillaume
    • www.umlchannel.com
« on: March 11, 2016, 03:04:19 am »
We defined a custom Programming Language via the Code Engineering Data Type feature; a new Product Name "test" has been defined with a number of Data Type e.g. Integer, String, Bool...
When I create a class with Language = test, I have the associated list of Data Type in my attributes window.
However when I add an attribute without selecting the data type, I always get "int" as the default data type which does not belong to my Product.
With built-in languages, there is a working default data type.
I exported the Model Data Types as a reference data and looked at the XML, but couldn't find any property to set a Data Type as default.
Any hint?
Also, how do I delete a Product I no longer need?
thanks
Guillaume
PeterHeintz
Re: Default data type in a new Code Eng. Language?
« Reply #1 on: March 11, 2016, 04:44:24 am »
Once you have deleted all your Datatypes your product is gone.
Regarding the default Datatype I am not sure, but if know similar problems with other kind of types.
I assume there is just no way for you to set a default of your types, and the “int” is somehow burned in.
Best regards,
Peter Heintz
Michel777
« Reply #2 on: March 12, 2016, 03:29:01 am »
I have the same issue. EA converts the DataTypes a follows:
EA  -> XML
Integer -> integer
Boolean -> boolean
OID-> string
UnlimitedNatural -> String
The same behavior, like typing anything for type  at creating of an attribute (e.g. Type in EA  "friedpoteto"  - Type in XML "string")
Thanks in advance,
Michel
