Author Topic: SOLVED: Can't connect to cloud server on Mac  (Read 7502 times)
Mauricio Moya (Arquesoft)
    • Arquehub Azure Module
« on: March 17, 2016, 07:06:08 am »
It is supposed EA is multiplatform, so I installed it on a Mac, but when trying to connect to a cloud server it throws an error number (-2147467261 in my case) and the connection is not loaded.
Has anybody tested cloud connectivity from a Mac?
« Last Edit: April 01, 2016, 03:34:00 am by MMoya »
Re: Can't connect to cloud server on Mac
« Reply #1 on: March 17, 2016, 08:26:56 am »
Did you install the mdac28 component in wine? (Usually done through winetricks)
« Reply #2 on: March 18, 2016, 06:35:53 am »
Yes, I have it installed. Any other thing to check? is it supposed to work fine on Mac? I also note that some diagrams (kanban, for example) don't behave well.
« Reply #3 on: March 18, 2016, 08:17:20 am »
I've personally used the cloud service from a mac.
If you've installed everything requested on the instructions I don't have any ideas. Probably worth sending a support request using the form.
« Reply #4 on: March 31, 2016, 08:16:36 am »
After a "succesful" instalation on Mac, when trying to connect to a cloud server, EA is throwing the following error message:
Microsoft OLEDB Persistence Provider
[-2147467263]
Requested functionality is not implemented.
Any ideas?
« Reply #5 on: April 01, 2016, 03:33:33 am »
SOLVED:
The problem was :
  • I was trying to execute EA from Wine
  • Missing IE6 installation
  • Missing CrossOver installation
  • Missing executing EA from crossover to install missing components
