Author Topic: Edit connection string Cloud Services Client  (Read 6521 times)
Tory
« on: March 18, 2016, 08:21:33 am »
Is there a way to edit a connection string in the SSCloudServicesClient.exe application. The "Configure" button allows us to configure various options but does not allow us to modify the connection string.
The reason I need this is because the IP address for our SQL server has changed due to a change in ISP. I have several connections setup to the same database IP address & I would like to simply change the address and leave all the other information the same.
If the application does not allow changing the connection string can you point me to the file that contains the string and can it be edted?
