Author Topic: MariaDB ODBC settings  (Read 6959 times)
Guillaume
    • www.umlchannel.com
« on: March 23, 2016, 03:24:13 am »
We use a MariaDB to store an EA project. Where MySQL ODBC driver works ok, I was wondering if anyone had tested the MariaDB ODBC driver.
I ran a simple test and I'm getting an Invalid Data Source... Check configuration error.
Any recommandation from Sparx?
thanks
Guillaume
Re: MariaDB ODBC settings
« Reply #1 on: March 23, 2016, 05:16:18 am »
It should basically be the same as for MySQL. I haven't combined MariaDB with EA so far (just in other configs).
« Reply #2 on: March 23, 2016, 08:37:37 am »
Is there any particular reason why you want to use the MariaDB ODBC driver? EA won't load a model from an ODBC driver it doesn't know about, and we haven't added MariaDB checks.
« Reply #3 on: March 23, 2016, 09:00:30 am »
AFAIK you can use the MySQL driver to access MariaDB. At least it's worth a try.
Guillaume
« Reply #4 on: March 23, 2016, 06:34:24 pm »
Hi Simon,
Thanks for your reply.
I'm experiencing errors with an addin when using MySQL ODBC on a MariaDB. Since I came across this issue before via other DBMSes, I have a feeling that using the MariaDB ODBC driver could resolve it.
What is the likelihood for the checks to be added for MariaDB driver? I think it's worth trying and I'm happy to test a beta version if you want.
Guillaume
Here is the link to MariaDB ODBC driver: https://mariadb.com/my_portal/download/connector-odbc/1.0/connector-odbc-1.0.5
Guillaume
« Reply #5 on: March 24, 2016, 08:48:46 am »
I'm not sure on your chances with official support for MariaDB. From my point of view, every additional database that we support is an extra headache (and I have enough.) I know in theory it's fully compatible with MySQL, but if it was I don't think you would be having an issue in the first place. Unfortunately, I don't think it would be as simple as I made it sound in my first reply.
What's the error you're getting? Maybe we can resolve that.
natvig
« Reply #6 on: March 28, 2016, 04:17:49 am »
I have used MySQL ODBC Driver 5.1.13 together with several MariaDB instances. As far as I can see it works great. Make sure you don't use the driver version 5.2.x or above. I have had some strange issues using the driver versions above 5.1.13. If I remember correctly Sparx also do not recommend versions above 5.1.13.
/Hans
