Author Topic: Extracting date-series data from EA (not date-time)  (Read 5438 times)
ChB
« on: March 23, 2016, 10:32:37 pm »
I'd like to have some time-series graphs such as "requirement count over time" and "Use Case count over time".
I think the built-in time-series dashboard chart can't be run retrospectively: I think it only generates a data point when it is run manually.  I want a graph that starts from a date in the past.
I'm using EA 12.1 with a local .eap file (jet).
I'm thinking I'll write a simple SQL Query to extract the data and then chart that in Excel.
An SQL Query like the following doesn't work because the CreatedDate field is a date & time.
select t_object.CreatedDate,
       count(*)
  from t_object
 where t_object.Stereotype like '*requirement*'
 group by t_object.CreatedDate
How do I get my query to return (and group by) the date part only (not a date-time)?
I assume I'd manually run the SQL Query in EA and then copy the data to Excel.
Re: Extracting date-series data from EA (not date-time)
« Reply #1 on: March 23, 2016, 10:48:23 pm »
You should look into the date functions of MS-Access SQL syntax to group the data by date (or week, or month)
Or otherwise you could also get all the data out and leave the aggregation to Excel.
Helmut Ortmann
« Reply #2 on: March 23, 2016, 10:55:44 pm »
this forum isn't the best to discuss SQL features. May be there is a possibility. Google could help you. I could imagine defining time slots and group by them. If it's feasible with your EA Database,Access???, I don't know.
If I couldn't find an SQL solution I would cyclically run the SQL and store the results, let say every hour/day or whatever in a database.
Helmut
ChB
« Reply #3 on: March 24, 2016, 02:24:23 am »
Partially solved:
A bit more Google-foo and I've worked out how to get just the date part of the date-time field.  Thanks Geert for the hint that refined my Googling:
select count(*) as Count,
       format(t_object.CreatedDate,"short date") as Creation_Date
  from t_object
 group by format(t_object.CreatedDate,"short date")
 order by format(t_object.CreatedDate,"short date")
I then copy those results to Excel for charting.
I shame I can't use EA's built in time-series charting gadget.
