Author Topic: Including external elements in reports  (Read 3949 times)
scummyman
« on: June 10, 2010, 05:41:47 pm »
During my very first project in Enterprise Architect I encountered the following problem.
I have two packages: A and B.
B has one diagram: B.D.
Each package has one component: A.C and B.C, respectively.
The thing is that if I try to use A.C in B.D (by pasting element "as a Simple Link", "as instance of Element" or "as a New Child") and generate a rft document, the component does appear on the diagram but its description is not provided.
What I want to achieve is a list of tagged values for each and every element that appears on the diagram. Coping and pasting "as New" is an option but in case I modify an element the changes won't appear in the copies.
Any help will be appreciated.
Bye,
Andrzej
Dermot
Re: Including external elements in reports
« Reply #1 on: June 16, 2010, 12:14:33 pm »
IN the RTF report template add the: Package | Diagram | Element - Section - but leave this blank to replicate the: Package | Element section. You can Set your Tagged Values using the Element field ValueOf() or using the TaggedValues Section.
« Last Edit: June 16, 2010, 12:15:20 pm by Dermot »
scummyman
« Reply #2 on: June 16, 2010, 05:26:00 pm »
That worked great! Thanks!
Andrzej
