Author Topic: Shape Script : adding package contents compartment  (Read 9851 times)
bITs.EA
« on: April 04, 2016, 06:51:35 pm »
Hi
I've created a custom Shape Script, but now I want to add an extra compartment showing the "package contents" (if this is selected in the diagram properties)...
This is my current shape script, but I can't find the needed info in the user guide to add the deparment. Can someone help me, please?
shape main{
noshadow = "TRUE";
h_align = "center";
v_align = "center";
if(hastag("Macroprocess Type","Management"))
setfillcolor(0,204,255);
if(hastag("Macroprocess Type","Primary"))
setfontcolor(255,255,255);
setfillcolor(0,43,255);
if(hastag("Macroprocess Type","Supporting"))
setfillcolor(142,237,255);
startpath();
moveto(0,0);
//lineto(15,50);
lineto(0,100);
lineto(85,100);
lineto(100,50);
lineto(85,0);
lineto(0,0);
endpath();
fillandstrokepath();
printwrapped("#NAME#");
Re: Shape Script : adding package contents compartment
« Reply #1 on: April 04, 2016, 07:06:18 pm »
Hey Stijn,
This is the section in the user guide that deals with adding custom compartments:
http://sparxsystems.com/enterprise_architect_user_guide/12.1/building_models/add_custom_compartments_to_ele.html
bITs.EA
« Reply #2 on: April 04, 2016, 07:15:15 pm »
So if I understand well, I should add this under my main script and it should work?
//Add compartments for Child elements.
shape ChildElement
     //So set the compartment name to "Contents".
     SetCompartmentName("Contents");
     //Add the child elements name to the child compartment.
     AppendCompartmentText("#NAME#");
EDIT: Tested the above and no extra compartment in the element... What did I do wrong??
« Last Edit: April 04, 2016, 07:41:45 pm by bITs.EA »
bITs.EA
« Reply #3 on: April 04, 2016, 11:13:06 pm »
I've tried using the script below, but no extra compartment with package contents is shown. Only when I use the "DrawNativeShape()" command, it works. But I want to add a compartment to a custom shape... So what should I change to add a compartment to the custom shape below?
shape main{
noshadow = "TRUE";
h_align = "center";
v_align = "center";
//Blue color scheme
//setfillcolor(0,204,255);
//Grey / Orange color scheme
setfillcolor(200,200,200);
//Blue color scheme
//setfontcolor(255,255,255);
//setfillcolor(0,43,255);
setfillcolor(255,140,0);
//Blue color scheme
//setfillcolor(142,237,255);
setfillcolor(225,225,225);
startpath();
moveto(0,0);
//lineto(15,50);
lineto(0,100);
lineto(85,100);
lineto(100,50);
lineto(85,0);
lineto(0,0);
endpath();
//DrawNativeShape();
shape ChildElement
« Reply #4 on: April 04, 2016, 11:23:37 pm »
I don't remember exactly how it worked anymore.
Wasn't there an example shapescript with a compartment?
http://sparxsystems.com/enterprise_architect_user_guide/12.1/building_models/example_scripts.html
Yes, there is an example at the link above. That should hopefully help you further.
« Reply #5 on: April 04, 2016, 11:39:07 pm »
What you try is not possible. The native form is the only one that can display the content.
« Reply #6 on: April 04, 2016, 11:49:59 pm »
Are you sure?
I don't see any DrawNativeShape in the example:
/ EDITABLE FIELD SHAPE
shape main
     rectangle(0, 0, 100, 100);
     addsubshape("namecompartment", 100, 20);
     addsubshape("stereotypecompartment", 100, 40);
     shape namecompartment
               h_align = "center";
               editablefield = "name";
               println("name: #name#");
     shape stereotypecompartment
               h_align = "center";
               editablefield = "stereotype";
              println("stereotype: #stereotype#");
bITs.EA
« Reply #7 on: April 04, 2016, 11:59:56 pm »
Yes, you have 2 distinct scenarios for the shape script of an element:
1) Adding properties / attributes of the element itself to a shape.
This can be done using subshapes (like in your example). This applies to native & custom shapes.
2) Adding properties of child elements of the element. (eg. add the names of all the child elements of a package)
This can be done using "shape ChildElements{}" IF you use a native shape.
This cannot be applied to custom shapes.
Unfortunately, I want to show ChildElements in a custom shape...
« Last Edit: April 05, 2016, 12:01:48 am by bITs.EA »
« Reply #8 on: April 08, 2016, 02:57:55 pm »
Custom shape scripts can't render either the built-in compartments or any child element compartments etc.
There's no call to "insert compartments into this position".
Geert's example isn't for compartments in this way. It's only rendering the name and stereotype as a subshape with the name "compartment".
« Reply #9 on: April 08, 2016, 03:48:26 pm »
Hey, that's not my example, but one of the examples scripts from the manual.
Kind of misleading is these compartments aren't real compartments then ain't it?
« Reply #10 on: April 08, 2016, 06:55:07 pm »
Pretty well done then, if they even mislead you xD
