Author Topic: Get Name of Opened Project in C#  (Read 6423 times)
Ceronimo
« on: April 11, 2016, 06:07:20 pm »
How can i get The Name of the opened Project ?
like f.e. myTextboxName=Attribute.Name;
Re: Get Name of Opened Project in C#
« Reply #1 on: April 11, 2016, 06:38:10 pm »
Repository.ConnectionString has this information.
Ceronimo
« Reply #2 on: April 11, 2016, 08:12:04 pm »
thank you,
worked for me have cut the string.
it give the path back
greetz Ceronimo
Uffe
« Reply #3 on: April 11, 2016, 09:06:44 pm »
Just to clarify this for anyone else who comes across this thread: there is no such thing as a project name in EA.
There is a project GUID, which you can get from the Repository class, but EA does not have a concept of a project name. That bit of text you see in the window's title is taken from different sources and does not correspond to anything in the EA database.
The "name" can be an alias taken from the DBMS connection string (which also holds the server and database name), or the file name if you're using .EAP projects or EA shortcut files.
The only case where you are guaranteed that the name will be the same for multiple users is if you're using an .EAP file. In the other cases, different users may have different names for the same project.
Depending on what you want to do with the text you extract, this may be important or it may not be. But in EA, projects do not have names.
/Uffe
« Reply #4 on: April 12, 2016, 09:34:25 am »
/Uffe
Along the same lines as Uffe has mentioned, we've gone to the extent of having a Top level branch called Instance:<Name> where we name the Repository in the repository itself.  As we use a number of very similar/clones of our main repository - and in any event our repositories have the same high-level structure, we need to make sure we're looking at the right one.   Indeed, as we make our clones (during overnight./backup processing) we rename the package and even test to make sure we're dealing with the right one in the right state.
Ceronimo
« Reply #5 on: April 13, 2016, 03:35:00 pm »
Top Feedback.
Thank you !
