Author Topic: Element Shadow Color doesn't change color with change of defined status  (Read 69611 times)
2pointO
Hello
I've set up my Enterprise Architect to show Element Shadows (in the Tools-Option-General-Diagram-Appearance menu).
After that I've created some custom shadows at Settings- Project Types - General Types and applied it to all elements.
As a result I have a normal grey default shadow shown, but it won't switch colors when changing the status to the right color.
Any hits on how to go about that?
Greetings Sarah
In former EA version the shadow was hardly visible, but visible. Current versions render the shadow merely invisible, but for me unusable. I also remember that turning it on test wise gave me a hard time. ICR the details, but View/Visual Styles might have some influence.
Instead of the shadows, where appropriate, I use shape script to create some meaningful highlighting (color box).
2pointO
I use EA Version 11 and the colors are working fine with a good distinction between background and elements but my collegue uses EA Version 12.1 and there only the default grey shadow is shown.
I already have a shape script on the elements, the shadow was an additional option to vistualize information the easy way, I thought :(.
Maybe it's a bug in the newest EA Version?
lg Sarah
No, I think it's not a bug but a feature. ICR when I had this encounter, but maybe when V12 was introduced. I'm pretty sure one of the Sparxians will comment later.
Have you also set Tools > Options > Diagram > Appearance > Element Shadows On?
What is the element type? The requirement-like elements, e.g. Issue, Change, Feature, don't have coloured shadows. There may be other types as well.
EDIT: I just noticed you said you are using a shape script. It appears that shape script shadows don't show status colours. I don't know if that is intentional or not: I suspect it probably is, because you have freedom in shape scripts to add any kind of status colouring to your shapes that you want. You could report a bug and get an official answer...
« Last Edit: April 14, 2016, 09:30:15 am by KP »
VKN
Did you check Show status colors on diagrams (Tools | Options | Objects) ?
I assume q was being ironic...
It's actually NOT turned off by the shapescript, there's a second setting that KP missed:  "Tools | Options | Objects | Show Status colours on diagrams" that controls whether the status colours are shown.  However, the shadows are VERY anaemic and hardly visible.  A more emphatic shadow would be preferable (perhaps a user selectable - even per diagram shadow width).
Yeah, no I didn't. Doesn't work with shape scripts. At least, not in my version of EA (which is, admittedly, a development build and quite different to anything out in user land).
Glassboy
I'm fairly certain that it has been stated before that it doesn't work with shape scripts.
YMMV - works for me...   ::)
I think we NEED to get to the bottom of this.   >:(
I've just noticed, not all shapes are responding to the show status colours - whether they do or don't have a shape script.  There SEEMS to be NO rhyme or reason...
It does seem to be related to the underlying t_object type however.
At a minimum we need a list of the shapes that don't respond...  But we really need them ALL to respond  - so we can decide.
Concistency, konsistency, consistensy! TMUffe - after Paolo
2pointO
Re: Element Shadow Color doesn't change color with change of defined status
« Reply #10 on: April 14, 2016, 05:28:04 pm »
Both setups have the exact same options. Only difference is the component color , but even if I change my component color as well it works fine. There is a clear visible shadow but just the color remains the same.
The Shapescript doesn't effect my shadow colors in any way , but even without the script the shadows doesn't work with EA 12.1
« Reply #11 on: April 15, 2016, 09:29:20 am »
Hi Sarah,
I see you're using Components.  Try using Classes.  As I said above, shadows seem to work for some element types and not others...  KP also alluded to that.
For Glassboy:  I originally mistyped "some" above as "somme".  Perhaps a Freudian slip?
Glassboy
« Reply #12 on: April 15, 2016, 01:23:02 pm »
I think you may just be going over the top with that one.
« Reply #13 on: April 15, 2016, 03:05:59 pm »
Now why didn't I think of that?  Good one!
« Reply #14 on: April 15, 2016, 05:30:03 pm »
Out of curiosity I tried this feature once again. So I looked into the options and found that the flag was turned on. But no colors. Of course.
Bow I remember that there is another page where to define the element to which the colors shall show. But where is that page compared to the Tools/Options? I'm in a maze of twisty little passages...
P.S. Ariadne helped me from within my brain. Now this dreaded 2nd option part (which I now realize has been mentioned in the original question) Diagram/Appearance/Configure Status Colores. Here I checked all elements to apply to and the color reappeared. Meanwhile it is even recognizable again.
« Last Edit: April 15, 2016, 05:38:41 pm by qwerty »
