Author Topic: How to show whole BPMN pools and lanes with activities etc. on several diagrams  (Read 6449 times)
oysteinholo
I want to model some BPMN models (with pools, lanes, activities etc.).
I want to relate (connect) some classes to the activities (showing which information is being used within that activity).
I want to do this in several diagrams, i.e. the process (or at least a pool from a process if one has defined a process to comprise several pools) is the same, but I want to on one diagram relate e.g. activity A with class X, and on another diagram relate e.g. activity B with class Y. On these diagrams the classes related to an activity may be related to a small number of other classes.
The intention is to visualize the information need/usage on the individual activities/steps in the processes. And then the lanes in the pools "connects" the information to a role.
I have tried to "copy" all the relevant BPMN-elements from the project browser onto a diagram, but I cannot make it work. Either only the pool is selectable in the project browser and the elements "contained" in it does not follow. Or if I select all the lanes they appear messy on the new diagram.
I have also tried to "copy" the whole process diagram onto another diagram. Then I have to choose to "drop" it in the diagram as either a frame, a diagram reference, hyperlink or list. None of these gives me the possibility to add a relation (connection) between a class in the diagram and a specific activity within the BPMN-process.
I believe this would be an essential functionality - is it possible to accomplish this one way or the other. Or do we have to consider some other tool like Troux or something like that?
In order to copy the diagram without copying the elements on it you can simply do a Ctrl-A, Ctrl-C, go to a new diagram, Ctrl-V
philchudley
Are you intending to use the same elements on all diagrams?
If so, try right-clicking the BPMN Process flow diagram, selecting Copy Diagram
Move to a new package and the paste diagram selecting a Shallow Copy from the options
If you want to create a brand new set of elements, then use Geert's suggestion or proceed as above and select deep copy from the options.
Cheers
Phil
Models are great!
Phil,
My way (select all, copy, paste on a diagram) has the same result as a shallow copy.
No new elements, only new DiagramObjects.
StefanPears
  • Unwissenheit schützt vor Erkenntnis nicht
CTRL-V and CTRL-Insert drop elements as link
SHIFT-CTRL-V drops element as new
