Author Topic: Enumeration Set - Tagged Value Type  (Read 6832 times)
« on: April 14, 2016, 05:21:27 pm »
We have a need to create a tagged value that is an Enumeration Set, sort of like a union of Enumeration and Check List types.
I couldn't find any safe way to do this.  Is this correct?
The only thing I could use is a comma separated string Tagged Value.
We need to be able to search the values so that we can if required search for more than one enumeration literal at a time.  (in the example of the string there would be multiple "contains" predicates).
There will be between 10 and 20 (or so) values so some other solutions aren't viable.
Anyone got any ideas?
Is the concept of such as tagged value type  be a good feature request?
« Last Edit: April 15, 2016, 09:30:28 am by Paolo F Cantoni »
Re: Enumeration Set - Tagged Value Type
« Reply #1 on: April 14, 2016, 07:07:49 pm »
I guess this has beed asked for already in the past. Still a good thing, though.
« Reply #2 on: April 15, 2016, 09:59:31 am »
Feature request submitted...
serodya
« Reply #3 on: April 16, 2016, 12:18:15 am »
Not sure if this can help you
Tagged Value Type = Spin
Type=Spin;
LowerBound=x;
UpperBound=y;
Default=Val;
Enables creation of a spin control with the value of LowerBound being the lowest value and UpperBound being the highest value. You can also set a default within that range.
Reference: "4 Tagged Value Types" page 81 in http://www.sparxsystems.com/downloads/resources/booklets/enterprise_architect_sdk.pdf
« Reply #4 on: April 18, 2016, 09:35:41 am »
Type=Spin;
LowerBound=x;
UpperBound=y;
Default=Val;
Hi serodya,
I guess I wasn't clear enough.  It needs to be a multi-valued set.  That is from the set of check boxes, I need to be able to select more than one.  Otherwise, a simple Enumeration would have done.  AFAIK, a Spin, only lets you select a single value.
