Author Topic: Relationship Matrix  (Read 4491 times)
aldrich
Relationship Matrix
« on: April 14, 2016, 10:36:25 pm »
I've set up associations between attributes in different Classes via 'Link to Element Feature'.
In the relationship matrix it shows the corresponding association but for the life of me I can't figure out how to get the attributes to display in the matrix as well.
The idea is that I have fields in a report that are associated with fields in systems, tables, other classes hat have you. I want to be able to do impact analysis...if a given system field changes, what are all the corresponding output reports fields that are affected.
If  the relationship matrix isn't the right tool, what is?
Aldrich
Helmut Ortmann
Re: Relationship Matrix
« Reply #1 on: April 15, 2016, 02:45:10 pm »
Hi Aldrich,
I'm not sure if it is possible with Relationship Matrix. Usually an Attribute makes no sense without the owning class.
I would use SQL Queries. To put the results into reports use Template Fragments aka sub Templates.
see:
http://sparxsystems.com/enterprise_architect_user_guide/12.1/report_generation/rtf_template_fragments.html
Helmut
