Author Topic: DocGen: Overridden attribute initializers  (Read 6914 times)
Uffe
« on: April 15, 2016, 11:25:20 pm »
Hi all,
I've got a class model with a lot of overridden attribute initializers.
Is there a simple way to access those in an RTF template?
OK then, is there a hard way to access those in an RTF template?
Cheers,
/Uffe
Re: DocGen: Overridden attribute initializers
« Reply #1 on: April 15, 2016, 11:37:54 pm »
Uffe,
What you do mean by "overridden attribute initializers"?
Uffe
« Reply #2 on: April 16, 2016, 12:51:42 am »
Well... Attribute initializers that have been overridden.  ::)
No sorry, attributes in a class which have been given their own initializers in a specialized class.
Which you do by right-clicking the specialized class and selecting Features & Properties -- Override Attribute Initializers.
There's no obvious node for these in the RTF template editor, so I'm wondering if there's a way to pull them out without creating a complicated fragment.
Or if that's the only option, where they are stored. Because they're not in t_attribute.
/Uffe
« Reply #3 on: April 16, 2016, 01:28:58 am »
Ah, don't think I've ever used one of those.
They are stored in the field t.object.RunState in the form of
@VAR;Variable=attribute1;Value=7;Op==;@ENDVAR;
There is a field "Run State" in the template where you can select Variable, operation, notes and Value.
Seems like you are in luck and there is indeed a simple way :)
Uffe
« Reply #4 on: April 16, 2016, 02:07:31 pm »
Coolness -- thanks, Geert! :)
/Uffe
