Author Topic: Generic relationships  (Read 7626 times)
« on: April 18, 2016, 05:51:52 pm »
I can't recall if the ArchiMate specification (or even UML) says this but for the sake of the discussion, let's assume that any arbitrary element metatype can be an aggregate of the same element metatype .
I can't actually specify that in Quicklinker, without specifying that each specific type aggregates to that specific type.  I can create (for example) a generic relationship definition  unstereotyped class to unstereotyped class but that would allow aggregation between different metatypes =- which may or may not be valid.
I thought one solution would be to allow the stereotype "<stereotype>" to mean an arbitrary stereotype - reuse of that extrinsic value in the same line would mean the same stereotype (and therefore the same metatype) and get around the problem and make [/size]Quicklinker definition files much smaller and easier to manage.
Thoughts?
Re: Generic relationships
« Reply #1 on: April 18, 2016, 07:01:20 pm »
How can something be aggregate of itself?
« Reply #2 on: April 18, 2016, 11:03:54 pm »
metatype, NOT instance.
This team is an aggregate of other teams... (for example)
« Reply #3 on: April 18, 2016, 11:31:52 pm »
That would probably be an easy improvement. +1
Don't ask me what I think of the QL handling in general. Waste bin and then design "something". It can't get worse.
Glassboy
« Reply #4 on: April 19, 2016, 07:12:12 am »
Furthermore, aggregation, composition, and specialization relationships are always permitted between two elements that have the same type.  Section 2.4 http://pubs.opengroup.org/architecture/archimate2-doc/chap02.html#_Toc371945148
Glassboy
« Reply #5 on: April 19, 2016, 07:13:44 am »
To understand recursion, you must first understand recursion.   ;D
« Reply #6 on: April 19, 2016, 09:24:32 am »
You might well think that, I couldn't possibly say that...   ;)
