Author Topic: Activity Parameters not staying-put  (Read 10306 times)
Polymorph
« on: April 20, 2016, 07:48:23 pm »
I have an activity that owns an activity parameter. When I draw an activity diagram and place the parameter on the diagram frame I locate it as required. I save the diagram and close it...
When I come back to the diagram the parameter has moved back to its original location. No matter how many times I save the diagram the parameter refuses so stay where I put it. I've also seen this behaviour with some of the control/object flows on the diagram. I've tried deleting the original parameter and replacing it with a new one but this doesn't help.
Has anyone else experienced this problem?
Re: Activity Parameters not staying-put
« Reply #1 on: April 20, 2016, 07:50:17 pm »
Have you tried by moving the Activity as well?
I can imagine that sometimes EA doesn't notice a small change and as a result doesn't save anything.
PeterHeintz
« Reply #2 on: April 20, 2016, 07:58:29 pm »
Just move you activity frame a bit more to the left, than it works.
Best regards,
Peter Heintz
PeterHeintz
« Reply #3 on: April 20, 2016, 08:01:06 pm »
Sorry! Wrong direction!
Move it a bit to the right!
Best regards,
Peter Heintz
Polymorph
« Reply #4 on: April 20, 2016, 08:14:30 pm »
Hooray - was about ready to throw my PC out the window! Thanks everyone!
PeterHeintz
« Reply #5 on: April 20, 2016, 08:26:02 pm »
I remember that I have send a bug report some month ago to Sparx.
Let's see if and when it will be fixed.
Best regards,
Peter Heintz
Volkan
« Reply #6 on: June 27, 2019, 05:26:16 pm »
Hi Peter,
I am really happy to tell you that it is still not fixed yet in the year 2019, more than 3 years after you report the problem!
avi10000
  • Programmer/Writer
« Reply #7 on: March 09, 2021, 08:09:30 am »
Hi all,
Maybe relevant: This was the easiest question I have ever written to this forum - because all I had to do was copy the question Mr/Ms Polymorph wrote above in 2016.
re Geert Bellekens suggestion (in 2016):
"Have you tried by moving the Activity as well?
I can imagine that sometimes EA doesn't notice a small change and as a result doesn't save anything."
What do you mean exactly by "mov(e/ing) the Activity (as well)"?
How do you do that?
re PeterHeintz (in 2016):
"Just move you activity frame a bit more to the left, than it works."
What do you mean exactly by "move you activity frame a bit more to the left (/right)"?
How do you do that?
Avraham
avi10000
  • Programmer/Writer
« Reply #8 on: March 09, 2021, 08:11:25 am »
I am using v15.1.
Maybe v15.2 fixed it?
Avraham
