Author Topic: Unable to remove unexpected text in template code (Package.Element.TaggedValue)  (Read 5430 times)
bockfu
I am creating a User Template/Fragment to include a table of Tag Names & Values.
Problem is, selecting the section for 'Package/Element/Tagged Value' results in some boilerplate/instructional text that I cannot delete.
Any way to workaround this?
I am on EA 12.0.1215, Corporate Edition
No, what I usually do in these circumstances is remove sections until I have a clean template again.
Occasionally that meant starting from scratch again.
bockfu
Geert, Thank you for the response.
After a few controlled tests, I understand the rationale for the practice you shared.  It seems the protected boilerplate/instructional text changes a bit over time and use.
I'll follow the approach you mentioned.
<edit>
In addition, I've found moving the checked section up/down via the arrow buttons sometimes resolves the issue.
Thank you.
« Last Edit: June 22, 2016, 01:37:48 pm by bockfu »
