Author Topic: Locate Classifier from Instance  (Read 11387 times)
YogaMatt
« on: April 29, 2016, 07:04:38 pm »
Scenario:
Instances of a classifier are in a different location to the classifier in the project structure.
From an instance on the diagram, can locate the classifier (either right click and find classifier, or shortcut Ctrl-Alt-G).
Issue:
When viewing the instance in the browser, Ctrl-Alt-G does not locate the classifier, nor is there a context menu.
Am I missing the trick, or is a feature request in order?
Cheers
Yoga
Re: Locate Classifier from Instance
« Reply #1 on: April 29, 2016, 07:21:52 pm »
Check View|Traceability
Default the classifier relations are not enabled, but there's a settings button on the view you can use to enable it.
YogaMatt
« Reply #2 on: April 29, 2016, 07:29:49 pm »
Thanks again Geert - helpful as always.
Though valuable, I want to be able to just navigate whether I have the traceability view open or not. Ctrl-Alt-G from instance in browser surely should navigate the classifier?
Cheers!
« Reply #3 on: April 29, 2016, 07:36:53 pm »
Yes, that would be consistent with the behavior of a selected object in the diagram and a valuable addition.  ;D
YogaMatt
« Reply #4 on: April 29, 2016, 08:10:18 pm »
I'll submit a feature request, referencing this thread.
Anyone wants to add support, give Karma ;-)
YogaMatt
« Reply #5 on: May 03, 2016, 05:46:14 pm »
Feature request submitted and Sparx considering for future release. In the meantime, remember to use Geert's valuable workaround.  :)
« Reply #6 on: May 04, 2016, 11:36:51 am »
go orthogonality and konsistensee
