Author Topic: RTF Report Generator: Alternatives?  (Read 5502 times)
Centurio
« on: June 24, 2010, 07:24:07 pm »
Hi all,
considering the recently made expereinces about the RTF report generator (this item seems to be _a little bit weak_   :()
gives rise to ask for alternatives.
Does anyone know some alternatives?
Regards
Centurio
« Last Edit: June 24, 2010, 08:12:15 pm by 2kandi »
Re: RTF Report Generator: Alternatives?
« Reply #1 on: June 24, 2010, 07:58:41 pm »
I've created my own report generator in the past.
It's a bit of work, but I think it pays off in the long run.
Centurio
« Reply #2 on: June 24, 2010, 08:14:03 pm »
Hi Geert,
seems it's the _only_ alternative  :-/
Centurio
beginner
« Reply #3 on: June 24, 2010, 08:40:02 pm »
Ah! Here you got that advice. Write down a hundred times: I shall not use the RTF generator.
Romanes eunt domus
b.
« Reply #4 on: June 24, 2010, 08:46:46 pm »
You can read some of my thought about report generators here
beginner
« Reply #5 on: June 24, 2010, 09:53:05 pm »
A good article. I concur in most places. Document creation is inevitable for any company using a modeling tool (for many reasons).
Here I don't agree:
...This document could be something in the form of a Rich Text Format, MS Word ...
The Standard.
Generating an average document (~50 pages) should not take much more then a minute.
But then an odyssey of many hours starts to bring the document in a format which suits the QA/CI of the company.
Like you I spent a lot of time writing a doc generator and it does pay off. However, I used LaTeX instead of Word and this payed of even more. Instead of doing hours of layout we can really click-and-print model aspects. It was just important (and difficult) to find out the aspects which needed to be brought to paper.
b.
« Reply #6 on: June 24, 2010, 11:22:12 pm »
Hmm, I must not have been clear enough in my description.
What I meant was that the whole process of generating a document (including formatting to please the audience) should not take more than about a minute.
So no more "odyssey of many hours", but in extremis maybe adding the version history or something like that.
LaTex might indeed be a suitable solution, but that depends on the circumstances, environment, and available resources (people).
beginner
« Reply #7 on: June 25, 2010, 06:54:41 pm »
I have seen and still see Word odysseys. From my point of view the last two words are synonyms.
Taking the LaTeX way is definitely not easy as you have a longer startup. But once you've done it, you get brilliant documentation. Here at my current customer I simply "did it". And the result proofed it to be the right way.
b.
