Author Topic: Connector.AssociationClass not present in EA.Interop  (Read 7823 times)
« on: May 08, 2016, 04:55:44 pm »
According to http://sparxsystems.com/enterprise_architect_user_guide/12.1/automation_and_scripting/connector2_2.html the EA.ConnectorClass should contain a property called AssociationClass, but I get a compile error when trying to use that.
Bug reported
Re: Connector.AssociationClass not present in EA.Interop
« Reply #1 on: May 09, 2016, 09:01:58 am »
Looks like that got into the user guide early. It is coming, but it's not available yet.
« Reply #2 on: May 09, 2016, 09:25:00 am »
And about time!   ;)
Will it apply to any connector type (not just Associations)?
We'd like to use the concept of a class (or shape) representing a binary relationship in a number of other scenarios / use cases.
« Reply #3 on: May 09, 2016, 11:03:03 am »
It's only providing a convenient API call for the existing behavior for Associations that are part of an Association Class.
It does not extend any other functionality.
« Reply #4 on: May 09, 2016, 05:06:58 pm »
Is the API returning the object corresponding to the value of t_connector.PDATA1, but does not require the t_connector.Type to be Association?  That all I think I need to know for now.
« Reply #5 on: May 09, 2016, 07:28:42 pm »
For those stumbling onto this post before the new feature has been released, this is the code in the Association class I wrote to implement it myself:
private AssociationClass _associationClass = null;
public AssociationClass associationClass
get
//TODO use the EA.Connector.AssociationClass property once fixed by Sparx
if (_associationClass == null)
int associationClassID;
if (int.TryParse(this.WrappedConnector.MiscData[0].ToString(),out associationClassID))
if (associationClassID > 0)
this._associationClass = this.model.getElementWrapperByID(associationClassID) as AssociationClass;
return _associationClass;
« Reply #6 on: May 10, 2016, 08:33:56 am »
if (associationClassID > 0)Should be
if (associationClassID != 0)
« Reply #7 on: May 10, 2016, 01:43:38 pm »
Why? Could the ElementID be a negative number too?
I guess in theory it could and only the value "0" is a special case to indicate no ID. I'll update my code.
VKN
« Reply #8 on: May 10, 2016, 02:19:17 pm »
I think an ID for anything could have a negative number, especially I guess if the model has replicas.
