Author Topic: Solved: Document Generation: Template Selector Fails  (Read 4292 times)
ChriDen
« on: May 10, 2016, 09:31:07 pm »
I'm having some problems with my Template Selector.
I created 3 Fragments:
HC Requirements (exists for a few weeks)
HC UseCases (new)
HC Activites (new)
All of them work just fine.
To test i declared them as templates, genereated information set them back to fragments.
The selector has the following entries:
Requirement::HC Requirements
Activity::HC Activities
UseCase::HC UseCases
Within the document template the selector is called this way:
<diagram
element>
{Template - HC Selector}
child elements >
Unfortunately this is only working with Requirements and fails completely for UseCase and Activity elements which are simply omitted.
Has one of you an idea what I'm doing wrong?
   Chris
« Last Edit: May 11, 2016, 03:55:36 pm by ChriDen »
PeterHeintz
Re: Document Generation: Template Selector Fails
« Reply #1 on: May 10, 2016, 09:55:05 pm »
Could it be that you have applied a filter in your templates?
Best regards,
Peter Heintz
ChriDen
Re: Solved: Document Generation: Template Selector Fails
« Reply #2 on: May 11, 2016, 04:05:24 pm »
*tilt* Thank You,
I thought i checked everything but the ChapterTemplate was filtered.
