Author Topic: Tagged values  (Read 3650 times)
Oopah
Tagged values
« on: May 10, 2016, 09:38:18 pm »
Hi all,
I have a logical model on EA, that I use to generate a GML application schema. On some compulsory attributes (string ones), even if the multiplicity is set to 1:1, and not nillable (nillable="false", default behavior), when I create a bogus XML file, I can leave the XML tag unfilled and it's still considered valid.
I tried putting a "minLength" tag at 1, but it does not translate into the XML schema. After looking into it, it seems that's because attributes are not treated as SimpleType. How can I force EA to tell its XML generator that a certain attribute is going to be a simple type ?
Many tahnks for any hints. :)
