Author Topic: Enums in XSD Transformation  (Read 7759 times)
Kyle W Melton
« on: May 12, 2016, 02:35:39 am »
Hello All,
Is there a way to make attributes of enum types generate into XSD correctly after running an XSD transformation?
Example:  I have created an enum (enum1) with a couple of possible values.  I have created a class (class1) with an attribute (attribute1) of type enum1.  When I execute the Model Transformation with the type of XSD, and then execute the "Generate XSD" feature on that transformed package, I get the following warning: "Warning no XSD type found for: "enum1".  Default is: xs:string".  This results in the following content in the xsd: "<xs:element name="attribute1" type="xs:string" minOccurs="1" maxOccurs="1"/>".  If I execute the "Generate XSD" feature before running the transformation, then the XSD comes out right....  Any ideas??
Thanks!
Kyle
