Author Topic: Allow larger patterns then 255 in XSD generation  (Read 4569 times)
« on: May 13, 2016, 12:07:02 am »
For IBAN Account numbers there's a pattern that is 848 characters long.
But the tagged value on the XSDSimpleElement only allows for 255 characters.
The usual workaround for things like this is to use <memo> as value so you can type in the longer content into the notes window.
Unfortunately the XSD generation is not smart enough to recognize this and simply generates &lt;memo&gt; as pattern
Can we please make the XSD generation a bit smarter so it can handle large patterns?
PS. The current workaround for this problem at my client is to change the database structure to enlarge the t_objectproperties.Value column. Unfortunately I cannot offer an alternative (yet).
Re: Allow larger patterns then 255 in XSD generation
« Reply #1 on: May 17, 2016, 11:55:44 am »
Hmm, I think you'll find this the EA database structure a hard limit, see for example File path too short (sorry I can't locate this in the new forum), guess that why you need the work-around.
