Author Topic: Generalization Set - API?  (Read 4200 times)
« on: May 16, 2016, 05:09:29 pm »
Before I submit a feature request, I just wanted to confirm there's no way to retrieve Generalization Set information via the API?
I want to use a shapescript to just put out the generalization set name (without the stereotype name).  There doesn't seem to be any way to do it.
Re: Generalization Set - API?
« Reply #1 on: May 17, 2016, 08:19:14 am »
By SQL. Have a look in t_xref where Behavior='generalizationSet'
« Reply #2 on: May 17, 2016, 09:30:56 am »
Thanks KP,
I already knew that.  I was asking about the API so I could get at it via a shapescript.  I don't want to have to write an add-in to return a value to the shapescript, if there's something coming down the line.
In particular, the generalization set name is ALREADY returned in one of the labels.  But:
1. It's joined like a "Siamese twin" to the stereotype - without an intervening space (so text wrap is problematic)
2. You can't suppress the stereotype in the label.
I'd just like a shapescript connector property that returned just the Generalization Set name.
