Author Topic: Export Package-Baseline to another package within the same model or to XMI file  (Read 4421 times)
kai23
Hi !
I am working on plug-in where I have to restrore a baseline from one package into a different (temporary) package within the same model. When trying via Project.DoBaselineMerge() I always get (among others) the error that the GUIDs are already present in the model - of course they are present in the original package.
How can I restore a baseline to a different package using GUID stripping ?
Also a workaround could be to export the baseline to an XMI file which then could be re-imported. But have not found any way to export a baseline via the automation API.
I think indeed you'll have to find a workaround with the xmi import from a file.
I think you can rather easily   :-\ export a baseline to a file. IIRC the baselines are simply xmi files stored in t_document. But they are not stored a plain text. They are first zipped and then base64 encoded.
So in order to make an xmi file out of a baseline you use Repository.SQLQuery to get the contents, then base64 decode it, and then unzip it.
