Author Topic: GetTreePos always returns 0  (Read 5640 times)
Mirko Sertic
« on: June 25, 2010, 10:07:41 pm »
Hi
I am running EA 7.1. When using a repository as model source, GetTreePos works perfectly. When using an EAP file, GetTreePos always return 0. Is this a known issue, and is there a work around available?
Thanks in advance
Mirko
beginner
Re: GetTreePos always returns 0
« Reply #1 on: June 26, 2010, 01:15:22 am »
It's only set once you move an item. The order you see in the browser is a mixture of "setting: sort" and once used move operations ordering some of the object types (like you will not be able to move packages below elements and certain elements within others). Weird it is.
b.
fwoolz
« Reply #2 on: June 26, 2010, 05:16:09 am »
B,
Ah, that's the secret!
Seems to me it would make far more sense to have TreePos reflect an item's position in the tree at all times under all circumstances...
Fred Woolsey
Interfleet Technology Inc.
« Reply #3 on: June 26, 2010, 05:25:24 am »
Yeah, but that would a bit too much sense for EA wouldn't it ;D
Mirko Sertic
« Reply #4 on: June 29, 2010, 05:30:58 pm »
Ok, thank you all so much for your help!
Regards
Mirko
