Author Topic: Hide Menu Bar in Workspace  (Read 7096 times)
« on: May 19, 2016, 05:35:31 pm »
For reasons I won't go into now, we'd like to create a specific perspective whose workspace contains no Menu Bar.  There doesn't seem to be a method to do that via the normal user interface.  However, is it possible to edit the .eaworkspace file to achieve this?  If so, how?
TIA,
Re: Hide Menu Bar in Workspace
« Reply #1 on: May 19, 2016, 07:47:28 pm »
Those files appear to be simple regedit export files.
« Reply #2 on: May 20, 2016, 09:04:28 am »
Export two with a change only to the position of the menu bar.
From that information you may be able to find what to break. But I suspect it will break more than you're bargaining for.
« Reply #3 on: May 20, 2016, 09:49:12 am »
Thanks...
Yes, I understand about breakage.  However, if I don't try I won't find out if I can get away with it...
« Reply #4 on: May 20, 2016, 10:11:26 am »
Thanks...
Tried that... TOO much changed for me to figure out which is the Menu Bar.  Beyond Compare reported 74 section differences in a .eaworkspace file <400Kb
Are the Toolbar IDs fixed?
