Author Topic: Enumerations - Empty attributes?  (Read 13853 times)
bob
« on: May 19, 2016, 07:24:41 pm »
Hi :)
Is it somehow possible to give an enumeration type's value the possibility to be empty?
I know that is was possible in EA 11 but doesnt seem like it is in 12.x!
Thanks again in advance,
N.O.
Re: Enumerations - Empty attributes?
« Reply #1 on: May 19, 2016, 08:50:38 pm »
You can remove the type, but I think that since version 12.1.1229 or so the default type is empty again (like it should)
bob
« Reply #2 on: May 19, 2016, 10:06:07 pm »
Well maybe this one wasnt defined clearly either:
I have an Enumeration type with the values:
A
B
C
D
now i want to add a fifth value which is empty..
So it would be:
A
B
C
D
Hope this clarifies what i need :P
« Reply #3 on: May 19, 2016, 10:20:06 pm »
Hmm why would you need that? I don't think that is even UML compliant.
StefanPears
  • Unwissenheit schützt vor Erkenntnis nicht
« Reply #4 on: May 19, 2016, 10:49:11 pm »
An enumeration value cannot be empty but you can give it a value like "empty", "unspecified", "none" or like that. And you can define a behaviour like writing a NULL value into a database table column.
bob
« Reply #5 on: May 19, 2016, 11:14:08 pm »
That sounds like a plan, how would I define that kind of behavior?!
StefanPears
« Reply #6 on: May 20, 2016, 01:10:28 am »
Well, there are a number of ways I guess. For example this one: Assuming you have a database class with stereotype entity and a UI class with stereotype boundary. The database class has an optional attribute (multiplicity [0..1] with a data type of your enumeration and the UI class has the same attribute but mandatory, then you can write into the database attribute description: if user selected 'none' from the dropdown then a NULL value is written   ....  or s.th. like that.
