Author Topic: Operation Links and CreationDate and Time  (Read 13599 times)
Re: Operation Links and CreationDate and Time
« Reply #15 on: June 29, 2010, 06:07:30 pm »
Graham,
Seems like registering went fine. The message you got is a standard warning message, not an error.
Have you moved the dll after registering it? The cmd file will register the dll in the same directory, so if you move it afterwards then EA can't find it.
SomersetGraham
« Reply #16 on: June 29, 2010, 06:14:50 pm »
Hi Geert
OK thats good to hear
I have not moved the DLL
If I look in the registry the correct path is shown .....
Graham
Using V12
SomersetGraham
« Reply #17 on: June 29, 2010, 07:16:45 pm »
Hi Geert
Got this working now
I was using 64 bit version of regasm
Using 32 bit version works
Graham
Using V12
« Reply #18 on: June 29, 2010, 10:04:37 pm »
ah, good, because I was running out of solutions ;)
