Author Topic: Choose Language for classes after abinary dotNet reverse engineering  (Read 2936 times)
TReichert
When I reverse a dotNet EXE all the classes are C#, regardless of the language defined for the model.
Filename is set to the DLL, that was used for reverse enginering.
Both is not usefull for code generation.
When I correct this properties for an individual class, code generation works fine.
But I import hundreds of classes, so it is undesirable to modify the properties of each class manually.
How do I import a dotNet  binary, so I can generate C++ files from the classes the reverse engineering created.
Thank you
