Author Topic: In the RTF report template how to filter on the Element connector taget type?  (Read 6726 times)
Mads Kirstan
I'm trying to make a Use Case, where I would like to list realized Features, but not the realized Requirements.
How do I filter on the Connectors target type?
Kind regards.
Mads Kirstan
Uffe
Hi Mads,
I'm not the world's greatest expert on RTF document generation (that would be Geert), but I don't think you can set a filter to catch that. I think you'll have to split your template into a "main" one and a fragment.
The fragment RTF should contain the fields you want (probably Name and Description, maybe Alias as well). Its custom query should, given an element, return only those Features which the specified element realizes.
/Uffe
I don't think I'm the greatest RTF template expert either, but I do think Uffe is correct.
I would probably make an SQL fragment with an sql statement similar to the following
select f.Name AS FeatureName, f.Note AS FeatureDescription from (t_object f
inner join t_connector r on (r.End_Object_ID = f.Object_ID
and r.Connector_Type in ('Realization', 'Realisation')))
where r.Start_Object_ID = #OBJECTID#
and f.Object_Type = 'Feature'
And then in the custom section add fields {FeatureName} {FeatureDescription}
Mads Kirstan
Thanks for the input! It worked like a charm  ;D
Maybe an enhancement for next version?
Kind regards
Mads
Kind regards
Mads
Only if you submit it as a feature request, please
