Author Topic: UI doesn’t respond to Use Rectangle Notation for Objects  (Read 3534 times)
If you create a shapescript which includes tests for Rectangle Notation (if(hasproperty("rectanglenotation","0"))) for most types of t_object types, the UI will create the [ ] Use Rectangle Notation context menu entry for the vertex.
However, for t_object.Object_Type=Object it doesn't.
I can see no real reason why it should not, particularly since the shapescript DOES respond to setting the Rectangular Notation to true by other means (directly in the DB).
Reported,
