Author Topic: Cannot update connector  (Read 7622 times)
msdb
« on: June 01, 2016, 06:30:34 pm »
In my C# program i have a method that should create a connector between two elements but it's throwing this error:
An unhandled exception of type 'System.Runtime.InteropServices.COMException' occurred in SparxProject.exe
Additional information: Cannot update connector as either the Start or the End object is NULL
The method:
static void LinkToSuperDepartment(Element subDepartmentOrEmployee, int superDepartment)
            Connector aggregationConnector = subDepartmentOrEmployee.Connectors.AddNew("", "Connector");
            aggregationConnector.Type = "Aggregation";
            aggregationConnector.Stereotype = "Archimate2::ArchiMate_Aggregation";
            aggregationConnector.ClientID = subDepartmentOrEmployee.ElementID;
            aggregationConnector.SupplierID = superDepartment;
            aggregationConnector.Direction = "Source -> Destination";
            aggregationConnector.Update();
The error occurs when Update() is called.
Do ClientID and SupplierID not specify the start and end objects of the connector?
Re: Cannot update connector
« Reply #1 on: June 01, 2016, 06:38:34 pm »
You don't have to set the clientID, that is set automatically because you add it to SubDepartmentOrEmployee.
But you have to make sure that superDepartment actually points to an existing element (that is already been saved)
msdb
« Reply #2 on: June 02, 2016, 06:24:22 pm »
Okay, I see my mistake now. Thank you.
