Author Topic: Actor classifier and instance  (Read 4370 times)
« on: June 03, 2016, 02:37:04 pm »
I have an actor (classifier) on a diagram - in rectangular notation.
I wanted to replace it with instance (to represent a specific type of actor).
How do I give the instance rectangular notation (i.e. make it look the same as the classifier was)?
tia
Simon
Re: Actor classifier and instance
« Reply #1 on: June 03, 2016, 05:07:28 pm »
Hi Skiwi, see my posts on Rectangular Notation over the last week.
Basically, you can create the shape script to render the rectangular form to your liking, however, if the t_object.ObjectType of the Instance is "Object" then you won't get the Context Menu item.  The shapescript will however, respond correctly to the Rectangular Notation test - if you can set Rectangular Notation by some other means.
Sparx have acknowledged the defect.
