Author Topic: RTF Documentation - Element filtering  (Read 4529 times)
TonyN
« on: June 03, 2016, 04:34:54 pm »
Hi Forum.
I want to create an RTF that only reports on elements that have operations.  I have tried all sorts of filters in various fragments and cannot seem to get an approach that works.  Any assistance would be greatly appreciated.
Kind regards,
Tony
Re: RTF Documentation - Element filtering
« Reply #1 on: June 03, 2016, 05:37:02 pm »
Hi Tony,
What you could do is use a virtual document and use an (SQL) search to determine to set of elements to report on.
TonyN
« Reply #2 on: June 06, 2016, 03:12:19 pm »
Hi Geert,
Thanks for your prompt reply however that int quite what I am after as the model search works across the whole model and I am only after the elements the current package (or sub package), that have operations and not the whole model.
Can you see any way of achieving that kind of filter.
BTW: the model search SQL I used is
SELECT t_object.ea_guid AS CLASSGUID,
   Object_Type AS CLASSTYPE,t_object.Name
FROM t_object, t_operation where t_object.Object_ID=t_operation.Object_ID
group by
   t_object.ea_guid,
   Object_Type,
   t_object.Name
« Reply #3 on: June 08, 2016, 04:13:05 am »
You can pass a parameter to the search in the tagged value of the model document.
Use that to limit the result to only the ones that matter.
I usually use the the GUID as parameter.
