Author Topic: REPLACING standard con labels with ShapeScripts  (Read 4211 times)
stao
« on: June 30, 2010, 08:12:44 pm »
Hi everyone
i used the search function and found many threads with interesting content but actually didnt found a solution for my problem.
here is my code:
shape main {
                noshadow="true";
            h_align = "center";
            lineto(100,0);
shape middletoplabel
            h_align = "center";
            v_align = "center";
            print("<<destroy>>");
shape middlebottomlabel
            h_align = "center";
            v_align = "center";
            moveto(20,0);
            lineto(80,100);
            moveto(80,0);
            lineto(20,100);
            print("#name#");
it works somehow but not in a way i want it.
in the label visibility it shows still the name of the connector (middletoplabel) and the stereotype (middlebottomlabel) .
and the default position of my new labels are NOT the same as the default positions of the normal unedited labels.
1.
it seems that if i edit labels i only edit the visual output of the label not the label itself
2.
If i edit labels the default position of the edited labels are not the same as before.
(After editing middlebottomlabel and middletoplabel have the SAME default position)
2 questions.
1. How to set the default position of the edited labels?
2. Not so important. How to REPLACE the label not only the visual output?
Stao
« Last Edit: June 30, 2010, 08:14:07 pm by stao »
stao
Re: REPLACING standard con labels with ShapeScript
« Reply #1 on: July 06, 2010, 07:27:15 am »
no one has an idea?
sry for double post..
« Reply #2 on: July 06, 2010, 09:03:20 am »
Can't be done with shape scripts which only change the appearance of a connector. You will need to change the connector properties: double-click it.
stao
« Reply #3 on: July 06, 2010, 06:11:18 pm »
ok
and what about the wrong default positions of the edited labels?
is there any possibility to set the default position in the shapescript?
or is this an EA bug?
