Author Topic: Exporting BPMN model into XPDL result in "empty" file (EA 12.1) (target: HP ALM)  (Read 11560 times)
Shegit Brahm
I have similar problems like these ones:
- http://sparxsystems.com/forums/smf/index.php/topic,23145.msg192681.html
- http://sparxsystems.com/forums/smf/index.php/topic,26723.msg207736.html
Here feature has been requested, but I don't see valid fulfilment so far.
- http://sparxsystems.com/forums/smf/index.php/topic,28678.msg214620.html
As I can say:
current EA 12.1 exports still conflicts with (almost) current HP ALM 12.2
My core question:
EA mistake or HP error?
Whenever I create a sample BPMN in EA and export the model, all I get is
- export as BPMN 2.0 XML
<?xml version="1.0" encoding="windows-1252"?>
<bpmn:definitions xmlns:bpmn="http://www.omg.org/spec/BPMN/20100524/MODEL" id="EAPK_E444FEBD_8B92_4fe2_87B3_83154728E814" targetNamespace="www.sparxsystems.com.au/bpmn20" xmlns:ssbp="www.sparxsystems.com.au/bpmn20" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:di="http://www.omg.org/spec/DD/20100524/DI" xmlns:dc="http://www.omg.org/spec/DD/20100524/DC" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" exporter="Enterprise Architect" exporterVersion="12.1.1224"></bpmn:definitions>
- export as XPDL 2.2
<Package xmlns="http://www.wfmc.org/2010/XPDL3.0alpha" Id="EAPK_E444FEBD_8B92_4fe2_87B3_83154728E814">
<PackageHeader>
<XPDLVersion>2.2</XPDLVersion>
<Vendor>SparxSystems</Vendor>
<Created>2016-06-08 09:56:55</Created>
</PackageHeader>
<TypeDeclarations/>
</Package>
I could export the package with the diagram only and got a bigger export file, but it failed with any of file names .xml, .xmi, xpdl.
I can't upload attachment here directly, can I?
Shegit
« Last Edit: June 09, 2016, 05:55:42 pm by Shegit Brahm »
Re: Exporting BPMN model into XPDL result in "empty" file (EA 12.1)
« Reply #1 on: June 08, 2016, 08:44:21 pm »
We were able to export our business processes from EA to HP ALM using XPDL.
I remember writing a script to export each process individually, and I think the guys at the HP ALM side had to do some manipulation on the file as well before it imported properly.
Shegit Brahm
Hi Geert,
thanks for sharing your experience.
If I understand you correct: until I do same things, I will ever fail?
Do you still have notes about changes in your files and changes in HP ALM and are you able/ allowed to share them?
If not, I know at least, I'm stuck here.
Shegit
« Last Edit: June 09, 2016, 06:13:48 pm by Shegit Brahm »
I'll check next week with the ALM guy what he did.
My script only exported each process individually, something you could do also manually, but that would be a lot of boring work.
It's the part on the ALM side which might be interesting.
Basically he took an example that did work, and made sure the EA file looked enough like the example to get processed by HP ALM.
Shegit Brahm
Thanks for your look-up.
I try a step in between:
The bizagi modeller http://www.bizagi.com/en/products/bpm-suite/modeler creates BPM models that are accepted by HP ALM without any postprocessing.
Idea is now to export EA into XPDL, import it into Bizagi and export it again in XPDL for import into HP ALM.
There is just the tiny problem, that these EA files often throw errors while importing into Bizagi like "does support only XPDL 2.1 & 2.2". If I can figure out a stable way to use this toolchain, I will explain it here.
Shegit
« Last Edit: June 17, 2016, 08:08:18 pm by Shegit Brahm »
What does your model look like? The files that EA has generated suggest to me that EA believes there is no BPMN content in the selected package.
Try creating a new package, create a single BPMN 2 diagram and create a single activity (from the BPMN2.0 toolbox) on that diagram. What is generated then?
Shegit Brahm
Hi Simon,
thanks for your suggestions.
I have several files to try:
First, like you said - simple an plain. This is generated by EA if I open a new project and say "BPMN 2.0 Collaboration Model"
eap file bmpmsimple.eap
export entire model bpmnsimple.xml
export as bpm XML bpmnsimple.xml.xml
export as XDPL, just shorten file ending manually bpmnsimple.xpdl.xml
Second, a self made with some more elements, not really complex at all.
export as bpm xml bmxbpmn5.xml
export as XPDL bmxbpmn5.xpdl
Import as BPM-XML just fails due to no XPDL.
Import from XPDL into ALM fails due to "no model"
I think you need to make sure you have BPMN Business Process element and underneath that a diagram with the lanes/pools and activities.
And make sure you have one process per package.
Shegit Brahm
With essential hint from Geert to export package by package I got solution workaround:
Exported file needs editing from
<Package xmlns="http://www.wfmc.org/[b]2010/XPDL3.0alpha[/b]" to
<Package xmlns="http://www.wfmc.org[b]/2009/XPDL2.2[/b]"
One of the reasons might be that the header states
<PackageHeader>
<Created>2016-06-24 10:41:23</Created>
</PackageHeader>
- the other, that ALM imports only 2.1 and 2.2
Clean project generated by EA: S-Project.eap
(includes all BPMN2.0 models as simple example)
Export settings have been "XPDL 2.2".
useless export of entire Model: S-Project-Model.xpdl
ALM finds nothing: S-Project-BProcess.xpdl
ALM finds no project but Process: S-Project-BProcessEdit.xpdl
ALM finds nothing: S-Project-Collaboration.xpdl
ALM finds no project but Collaboration:  S-Project-CollaborationEdit.xpdl
With your help, I mastered EA to "convince" ALM, it is just far away from expected.
