Author Topic: MDG Technology - Default Appearance as Icon  (Read 6031 times)
rvi1cob
« on: June 08, 2016, 07:26:07 pm »
Hi Everyone,
I am new for developing MDG Technology, wondering to get some help.
I have to create custom elements for my project and below is the requirement. While creating new elements in the diagram, the element should pick-up a default icon for appearance.
This is what I tried, (as guideline)
1. Created a Stereotype for my metaclass
2. In the Option : Edit with profile helper -- Assigned - icon (16 x 16) and _metatype: block
After generating MDG file and importing my MDG Technology, I tried to create a new element in my MDG diagram, but found that
1. In the toolbox - icon is assigned
2. When I drag and drop the element to create one, it has the default box. But here the expectation is the custom icon.
Any guidance, what exactly should I do to acheive this?
Regards
Vijay
Re: MDG Technology - Default Appearance as Icon
« Reply #1 on: June 08, 2016, 07:39:15 pm »
You need to create a shape script that will do the diagram rendering and assign it to the _image attribute. Just add an _image attribute and click the ellipsis button in the Initial Value. That lets you write the shape script.
« Reply #2 on: June 08, 2016, 08:55:13 pm »
Using the profile helper you click on the shape script tab and the button Edit.
You can use an image in the schapescript as well.
Below is an example from one of my stereotypes:
shape main
DefSize(36,24);
SetPenWidth(1);
Rectangle(0,0,100,100);
image("BAM icon_dial",2,3,98,97);
The "BAM icon_dial" has to be imported in the image manager
rvi1cob
« Reply #3 on: June 08, 2016, 10:36:04 pm »
Hi Geert,
Thanks for the hint.
I tried in the shape editor and in the preview, it showed the desired icon.
But it is still not working, after generating new MDG and importing it.
Note: The default appearance setting is reflecting correctly when I drag and drop for creating new elements.
Any other settings that I should check.
Regards
Vijay
« Reply #4 on: June 08, 2016, 11:34:00 pm »
Make sure to include the image in the MDG as well.
rvi1cob
« Reply #5 on: June 08, 2016, 11:58:50 pm »
Yes. already included  :(
rvi1cob
« Reply #6 on: June 18, 2016, 12:40:26 am »
found the problem. It works only when the metaclass is of type "Class". I was using metaclass "Table".
Thanks for your hints.
Regards
Vijay
