Author Topic: Code generation giving wrong file extension for class after language change  (Read 3621 times)
AJFleming
Hi -
new user, so be gentle.
I'm trying to generate code from a model which I've developed. First time through, I found that one of the classes was marked as being python, and it generated a .py file - even though the rest of the model was Java. I changed the language of the class to Java and generated the code again - and the class in question still generates a .py file - even though it's java inside.
Anyone else seen this?
Cheers,
Adam
Changing the language doesn't remove or change the existing filename setting. Just set it again before generating and you'll be fine.
