Author Topic: Problem in RemoteDebugging  (Read 4815 times)
Nishtha
« on: June 10, 2016, 08:54:41 pm »
I am trying to connect a java project which is set up on debugging on a remote computer. I need to create a sequence diagram. I have connected it with EA v12. For the first time, the debugger runs successfully on the computer but after that the debugger does not stop at the break point no matter how many time I try. I even uninstalled the application and created a new project but still the same problem persisted. But when I tried to run it on different machine, again for the first time it ran successfully and yet again nothing worked.
Kindly provide me a solution on how can I get this issue resolved?
Thanks in advance...
akshit bhatia
Re: Problem in RemoteDebugging
« Reply #1 on: June 15, 2016, 03:54:35 pm »
Hi Nishtha, I also am facing the same problem. Did you get any update from them? In my case I tried it on my new system. The debugging point was getting resolved and the remote connection was connected to the EA but still the debugger ignored the breakpoint.
RoyC
  • Read The Help!
« Reply #2 on: June 16, 2016, 09:28:40 am »
Did either of you submit a bug report to Sparx Support?  Use the link in the Support column at the bottom of the Forum screen. (Fifth column from the left.)
Best Regards, Roy
