Author Topic: Implement C# property in interface  (Read 11668 times)
jepessen
« on: June 15, 2016, 07:26:06 am »
I want to implement a property in a C# interface, so when I generate the code I obtain something like:
public interface IMyInterface
   string MyString { get; set; }
and in inherited classes:
public class MyClass : IMyInterface
   public string MyString { get; set; }
I've tried to add as attributes of interface my properties
But when I generate the interface I obtain the following code:
using System;
using System.Collections.Generic;
using System.Text;
using System.IO;
namespace MyNamespace {
public interface IMyInterface  {
}//end IMyInterface
}//end namespace MyNamespace
What's the correct way to implement properties in interfaces?
VKN
Re: Implement C# property in interface
« Reply #1 on: June 15, 2016, 09:53:30 am »
Did you try selecting a property on the dialog and fill up the Property field?
jepessen
« Reply #2 on: June 18, 2016, 05:37:09 am »
This is what I set now:
And now this is the interface in EA:
And this is the code:
namespace VCS {
  public interface Repository  {
  string Remote{
    get;
    set;
}//end Repository
}//end namespace VCS
The code seems correct now, thanks. But since it's the first time, I'd like to know if it's correct the UML class representation for the property, since I see the property twice.
« Reply #3 on: June 18, 2016, 06:51:38 am »
You don't see it twice. The upper is the property (the "storage") and the lower is the method you access it (it's marked with a <<property>> stereotype). This way the code generator knows that it must spit out the get/set. For different target languages the code will look different. Some languages even don't have explicit getter/setters.
jepessen
« Reply #4 on: June 18, 2016, 07:08:20 am »
Ok now I understand. Thanks for the explanation.
