Author Topic: Diagram Patterns in MDG  (Read 5823 times)
Amy_N
« on: June 18, 2016, 06:49:48 pm »
Hi. I have included some diagram patterns in my MDG that appear in various toolboxes. I have developed the MDG in a separate model and then added the MDG to our company model (server based).
Some of these patterns include elements that I would like to use an alternative image for. I have noticed when I do this for an MDG that is developed within the model it will be deployed in it all works fine. However when I do this for my MDG that has been developed in a separate model the diagram pattern works but it displays as the default image.
I have tried both importing the image with the MDG and having an image with the same name in the main model. I know I could use a shape script. However the image is a logo and the resolution is poor when I use an emf or jpeg version (but very clear when using the PNG version directly through 'alternate image).
It's actually for a diagram title bar that I would like users to be able to drag onto their diagrams. If there was a way to display this on all diagrams in the model as a default that would actually be a better solution but I couldn't find this option anywhere.
« Last Edit: June 18, 2016, 06:53:52 pm by Amy_N »
Re: Diagram Patterns in MDG
« Reply #1 on: June 18, 2016, 08:00:51 pm »
Hi Amy,
Not long ago I had a similar request from a customer.
He wanted a default title bar with image and diagram info.
What I did was create a small vbscript that looks for the template diagram and finds the diagram of the same type.
It then copies everything that is on the template diagram to this diagram;
So now my client can create different templates for different types of diagrams.
You can find the script here: Add defaults from template diagram
If you install EA-Matic you could even make this script run automatically after creating a new diagram.
Amy_N
« Reply #2 on: June 18, 2016, 11:46:09 pm »
Thanks Geert will check that out!  :)
