Author Topic: Multiple instance of custom tag in element possible?  (Read 9171 times)
Adsky
« on: June 20, 2016, 07:18:06 pm »
Hi.
I've created a custom tagged value : a reference to a JIRA task that realize a Requirement. Is there a way to enter two or more instances of the tag in for an element, for when a requirement will be realized by more than one task?
Andrew
PeterHeintz
Re: Multiple instance of custom tag in element possible?
« Reply #1 on: June 20, 2016, 07:38:11 pm »
Tag name needs to be unique. However you could store your references as a list in the tag value.
Best regards,
Peter Heintz
« Reply #2 on: June 20, 2016, 07:48:22 pm »
You can make as many tagged values with a given name as you want (no need for unique names).
There a little options button on the tagged values window that will toggle the option to show tags with the same name.
PeterHeintz
« Reply #3 on: June 20, 2016, 08:23:22 pm »
Hups! That is a feature I did not realized up to now!
Best regards,
Peter Heintz
Adsky
« Reply #4 on: June 20, 2016, 09:16:20 pm »
Thanks guys
Adsky
« Reply #5 on: June 20, 2016, 09:22:59 pm »
PeterHeintz: are you refering to an actual 'list' structure, or do you mean comma separated values in a single string?
« Reply #6 on: June 20, 2016, 09:38:45 pm »
You can specify a TV as being a drop down. Enter the following in the Detail of a new Default TV:
Type=List;
Values=A,B,C;
Default=A;
and you have a list.
PeterHeintz
« Reply #7 on: June 21, 2016, 01:53:16 am »
I did not refer to a specific solution: A comma separated string list could do that or a maintained list (if you are able to). Another possibility would be using the EA JIRA Connector (http://www.deiser.com/ea-connector-for-jira/ ) and using relationships rather than tags.
Best regards,
Peter Heintz
