Author Topic: EA 13 beta - crashes when using Kanban diagrams  (Read 4122 times)
JohnDoe
  • EA rocks !
« on: June 21, 2016, 09:29:10 pm »
Steps to Reproduce:
Open a new diagram and switch to Kanban. Configure and add a model, then add filters. When you end the Kanban dialog, EA retrieves the elements from the model and when trying to refresh the diagram, it crashes. After restarting EA and openening the diagram you can see the lanes and elements. So it looks like a crash in the refresh procedure.
When I use the kanban dialog to change appearancethen the refres works. It seems to be a problem if the data source was changed using configuration and/or filter panel in the kanban dialog.
