Author Topic: using <ModelView> stereotype in a script  (Read 5217 times)
steve.anderson
« on: June 30, 2016, 07:53:02 pm »
I am writing a vbScript based Script that create a diagram and then places 3 object with the stereotype <ModelView> on to the diagram to display usage information about an chosen element.
My issue is that I have the Object created but I can't seem to assign what is in the Source Attribute of the object (the piece with the SQL query for it to display).
Thanks in advance.
Re: using <ModelView> stereotype in a script
« Reply #1 on: June 30, 2016, 10:46:49 pm »
I might be able to help if you provide a little bit more information on what you are trying to achieve, and where you are stuck.
PeterHeintz
« Reply #2 on: June 30, 2016, 10:50:15 pm »
The SQL goes into the tagged value “ViewProperties”. So you have to manipulate that tagged value.
Best regards,
Peter Heintz
