Author Topic: Issues with report generator  (Read 5108 times)
Richard Burke
    • Protean Electric
« on: July 02, 2016, 12:00:41 am »
I am trying to generate a report that contains a subset of the diagrams in a package. Some of the diagrams are state machines that are tied to blocks so the project looks something like this:
-Model
  -Package
    -Block definition diagram
    -Sequence diagram
    -Block1
      -StateMachine
        -StateMachine Diagram
    -Block2
      -StateMachine
(By the way, how do you attach a diagram to a post? When I press the Insert Image button all I get is an opening and closing img tag with no option to select a file.)
I am familiar with master and model documents. If for example I only wanted to export the StateMachine diagram for block 2 to the report, how would I do it?
I can only point the model document at a package so how can I filter on just the one state machine diagram?
Any help would be gratefully received.
Richard
Richard Burke
Software and Systems Manager
Protean Electric Limited
Re: Issues with report generator
« Reply #1 on: July 02, 2016, 01:10:59 am »
Hi Richard,
In order to post an image you first have tu upload it to a public image hosting site such as imgur an then use the url in an img tag.
I always use modeldocuments with an sql search based on the guid for cases like this.
Richard Burke
    • Protean Electric
« Reply #2 on: July 02, 2016, 02:42:40 am »
Thanks on both counts, Geert.
I'm still mystified why I can't get the filters to work correctly but I suppose SQL will work instead.
The image I was going to upload for the original question is as follows:
Richard
Richard Burke
