Author Topic: Tagged Value re-use  (Read 9352 times)
Tagged Value re-use
« on: July 06, 2016, 03:57:34 pm »
A nice feature of the Sparx MDG is that I can create a General Tagged Value Type such as:
Effectiveness:
Type=Enum;
Values=Very,Generally,Sometimes,Hardly ever,Almost never,«Unspecified»;
Default=«Uninitialized»;
And in the MDG assign that Tagged value type to a stereotype (metatype) as:
<TaggedValues>
   <Tag name="Effectiveness"/>
</TaggedValues>
Notice how I've not had to put in the explicit values at this point (You CAN, but there's no need - EA will helpfully provide the drop-down)!  8)
The NEAT thing is that if the main definition changes (like I alter the enumeration literals), then the metatype's version will automatically take on the new values in the drop-down.  8)
What I'd like to be able to do is now define:
<TaggedValues>
   <Tag name="ExpectedEffectiveness" type="Effectiveness"/>
</TaggedValues>
and have the tag inserted into the item as ExpectedEffectiveness but still provide the drop-down from Effectiveness.
As far as I can make out, there is no way to achieve this?  :(
Can anyone confirm you can't re-use a Tagged Value definition in this way?
Also, is this a desirable feature? Should I put in a feature request?
Re: Tagged Value re-use
« Reply #1 on: July 06, 2016, 07:10:56 pm »
I guess you need to look up MOF or whatever document from OMG specifies it. Most likely TVs are not typed (just a guess).
« Reply #2 on: July 06, 2016, 09:05:37 pm »
Paolo,
If you define your profile properly you create an enumeration that contains the values of your tagged values.
Then you can reuse this enumeration in as many tagged values as you like.
So in a way this feature already exists.
« Reply #3 on: July 07, 2016, 09:45:17 am »
Paolo,
Thanks Geert,
But ALL that does is to make copies of the values into the particular stereotype, there is no referencing mechanism to provide one source of truth WITHIN the MDG, it's external.
I already have that functionality within the MDG.  As usual, I'm after something more.    ;)
« Reply #4 on: July 07, 2016, 09:46:55 am »
Does it matter what MOF says?
Sparx EA ALREADY types Tagged values" type=<structured TV type>.
I'm just after a natural extension.
